R RSTTYPE85 RSTTYPE87 NOW Joined May 26, 2001 May 30, 2005 #1 OK the t63e has served it's purpose (breaking in the engine). Now, looking at my signature what turbo would you recommend? Thanks, RS
S STP Narrow A$$ Racing Joined May 30, 2001 May 30, 2005 #2 A 45A from Limit Engineering..It's proven
R RSTTYPE85 RSTTYPE87 NOW Joined May 26, 2001 May 30, 2005 #3 What do you think about the PT74 turbo? RS
S STP Narrow A$$ Racing Joined May 30, 2001 May 31, 2005 #4 Honestly, I don't know much about it as I've never run it. Sounds like alot of turbo to me. How much power are you planning to make with that 4.1? I run a 45A on my driver...I've been 127mph with that turbo.
A azgn New Member Joined May 24, 2001 May 31, 2005 #5 63E and 45A are the same turbo think I would wait until you max the 63E which should be high 10's then if you wanna go faster, upgrade the turbo & heads (70-72 turbo & alum heads)
S STP Narrow A$$ Racing Joined May 30, 2001 May 31, 2005 #6 45A doesn't have a 66mm comp wheel? It was my understanding that the TE63 and 45 were the same...Not the case with the 45A.
A azgn New Member Joined May 24, 2001 May 31, 2005 #7 63E and 45A have the 66 mm wheel......63 and 45 have the 63mm wheel.......sometimes hard to figure out what is what....
S STP Narrow A$$ Racing Joined May 30, 2001 May 31, 2005 #8 Ohh I didn't realize the E specified 66. Thx Woody! In that case stick with what you have RS.
