what converter is this
1fast6
Pulled my 2004R the other day and the converter that was in there has what appears to be "Z" stamped all
the way around it.
Are there any other markings to ID this converter?
the replacement next to it:biggrin:
I don't think it's a D5. Probably explains why it wouldn't spin the tires in the rain with a TE44....
Can someone decipher code; HDCB?
I found this website but my converter code is not on it...
http://www.gmtuners.com/gmtransinfo.htm
there are some other stampings; 10 05 4677 L K1 2K 035
well i've pretty much worn out google searching for info on this converter. was really just curious about what it came out of and the specified stall speed.
What was your stall at 0 psi? I had a stock rebuild done on my trans years ago and it came back with a converter stalling about 1200 rpm :eek:
Looks like a cheapo DACCO rebuilt one to me. They were the only "gray" converter I ran across in all the years playing with the trannys.
If the tranny was painted grey as well it may have come from jasper. They seem to like grey for some reason, even on their converters.
---K-factor----- (stall)
Z = 203------- 2375rpm
Z = Heavy Duty Spring Damper, Woven Carbon Material.
Are you sure about the HDCB code?
H = Rear Wheel Drive 200C, 2004R, 700R4 etc.., 1.750” Hub Diameter, B-24 Family.
------K-factor----- (stall)
D = -- 180------- 2095rpm
--------Damper style
C = --Light Duty Spring Damper, Paper Friction Material.
----Bolt circle
B = 237 MM.
