Sixstringterror
- Nov 13, 2006
I need to know what wires to hook to my boost solinoid from the ecm....I cut the wires under the hood that goes to the factory boost sol. thinking I would not need it for my external wastegate and electric boost controller. Now ive been told that I need to have the factory B/S/C hooked up to keep the check engine light off. I have also heard that If you have an aftermarket chip that it may not cause the check engine light to come on.....I have an extender extreme g chip with the external wastegate...Will this chip cancel it out or not..If not then I need to know what wires from the ecm that I can tie into and plug the boost sol. controller up under the dash by the ecm...Make sence,.....Tim
