I have a V-8 radiator in my 84 T-type.I bought the hoses for stock car.Only problem,and it's not really a problem is,With the radiator as far as it can go to pass. side the other end sticks out from under the shroud like 6 inches.Normally the hose follows tight to the shroud on the driver side.This is not the case with the wider radiator.So because the hose hooks up say 4-6 inches from stock location,my kenne-belle cold air intake has a tighter fit and the hose dosen't really sit down in the half round hose bracket on the coil pack/ign. mod.HTH
