Will Rhoades
- Nov 13, 2012
I used to be able to set my TV cable the GM recommended way. I'm not exactly sure why I can't now. I try depressing the brass D part and push the slider all the way to the firewall. When I press the gas pedal down (without the mat) It will only ratchet the first click and no further. I tried another TV cable from Highway Stars with the same result. Last time it worked I had a 65mm precision plenum. I changed that one out for a stock plenum. I have had the pan off and tried moving the TV plunger/lifter and it seemed to take a good amount of pressure with my thumb to bottom it out. I'm definitely not a mechanic and I am not sure if this is normal. I was thinking about getting another 65mm precision plenum and seeing if that makes a difference with the geometry. That plenum is advertised as a stock replacement so it should work going back to stock. I am 99% sure my TV cable is a stock part. I'm at a loss for what is could be hindering this self adjustment. Any further input would be great. Thanks in advance!
