I purchased new vacuum lines for the turbo via one of the site sponsers. It was an original GM set up.. After the install of the new vacuum lines, I couldnt get more than 10lbs of boost. When I took the lines back off and checked out the "Y" splitter, I noticed there was a brass diaphragm to make the hole smaller at the back of the "Y".. The old one had the diaphragm at the top of the splitter so one side is free flowing..
Which one is correct? If the old one is, what vacuum line gets connected to the restricted part of the splitter... ?
Thanks>>
Thanks>>
