robztheman
- Apr 21, 2008
I had a transmission fail maybe 1000 miles give or take after I purchased my car. The trans had a few hundred miles on it at most from the previous owner. I sent my car to a reputable local trans guy. He builds a lot of race car guys transmissions here in Houston. After several failures, 4 I think. The first from a broken forward clutch shaft, it snapped. The second time he thought it was from my trans brake. The last failure I made it about 10 miles, and had my car towed home. I know he rebuilt the converter 2 times. I would get a few blocks down the road then I think on a 1st to 2nd shift the trans would die. and then no gears.
I purchased a new trans from David Husek and haven't looked back.
Years later (today) I took apart the old trans, now I have a few questions.
One of the Center support bolts is welded. Could the have caused the failure?
I think the check ball that goes in the input shaft was installed on the wrong side of the shaft.
Why? I have no idea.
What would cause this to the intermediate band?
Here is forward clutch tig welded.
I would like to fix this transmission myself any help is appreciated. Could it have been the converter this time that failed? Everything else looks good as far as I can tell all the frictions look new. Nothing burnt.
Thank you
Rob
Thank you
Rob
