My TTA is doing the same thing!?!?
on WOT, it will rev limit in 1st and never seems to hit second gear till I let off, but instead it seems to drop into 3rd (missing 2nd?).. in normal driving, it will rev high in first and then seem to skip second and drop into 3/OD or somthing.. tranny 'slipping' quite a bit.
I did noticed some slight Tranny fluid leaking. the other gears began slipping over time..
I dont want to go crazy re-filling tranny fluid, afraid of overfilling. I Gave it 3/4's quart today and the slipping is decreasing, but still seems to be missing 2nd.
From reading the forums, the GOV spring issue seems to have similar symptoms. I was'nt able to find much info that made sense to me about 'TV cable'.
Or, could be shy on fluid.. Dip stick seems to read ok to the line but fluid film to the line is very light.
Should fluid be heavy on the tranny dip stick?
How many quarts does the 2004r hold?
Any help?
