Hot Air 85
turning parts into TR
- Sep 25, 2006
I have an 85 Hot Air with the TPS way out of whack...scan tool shows 4.31 volts at idle and 4.41 at WOT. This is the max of the adjustability, I cannot get it any lower of higher regardless of movement. I have a really good feeling the scan tools right because it's pig rich in closed loop.
Does this mean I have a bad TPS?
If I have a bad TPS can I use the 86-87 unit?
I went to advance auto(it's local) to price a new sensor and they wanted $262.00 for the 85 sensor and $56.00 for the 87 sensor.
Any advice is appreciated, I didn't expect the TPS to turn into the $200 question.
Thanks, Jeff
Thanks, Jeff
