I've been hearing a phantom noise coming from my '87 Grand National. While changing the oil pan gasket I discovered the crankshaft has .016 play front to rear. According to Mahle, the MB3064P .020 thrust bearing I have was originally 1.098 width. It now mics. out at 1.085. The crankshaft thrust surface appears undamaged, but the bearings I need have been long discontinued. Mahle says the thrust is .040 wider than oem. The engine is still in the car, and has been balanced. Anybody know who makes the bearing set I need?
I believe I have a torque converter issue (ballooning or pump clearance issue) that I will address before the car runs again.
