I have been trying to determine the cause of my failed thrust bearing on a motor with less than 2000 miles on it.
I have been posting in the general tech area, see http://www.turbobuick.com/forums/showthread.php?p=1341613#post1341613
for the details.
I think I have narrowed my problem down to the transmission. Possible concerns are ;
1. Ballooned converter: Converter is a Pro torque, it has been reviewed and shows no signs of ballooning.
2. Restricted cooler passage: I have not been able to determine this is not the issue. What I would like to know is what can a restricted cooler do. What are the actual results of such a problem. Does pressure build through the pump and force it's way into the converter which will then apply pressure to the crank?
3. Improperly installed torque converter: Improper spacing and shimming, I did not use any shimming spacers when I bolted the converter up. How can this generate an issue.
Finally when I was disassembling the transmission from the block, I did have an issue with the snout of the converter coming undone, it had to be pried from the crank snout. How if at all could this cause an issue?
for the details.
