ChrisCairns
Senior Member
- May 24, 2001
I'm ready to mount my 90 mm Ford throttle body. (Get your minds out of the gutter, not mount it THAT way. :biggrin: )
I can do without the IAC I think so that leaves me with needing a TPS sensor and a cable connection. What does everyone use for a TPS? For input into an older sequential FAST?
And if I flip the TB over, the cable needs to be pulled basically straight down, not straight back like our stockers. But doing this flip puts the cable bracket on the correct side. If I put the TB in it's "normal" orientation the cable will be on the passenger side and would need to be pulled straight up.
Any and all suggestions appreciated.
