My set up is a TA-49 turbo, 43.5 lb 009 injectors, stock intercooler, DIY alcohol kit, Turbo Tweak alcohol chip, adjustable regulator, hot wired Red’s XP pump with a TH down pipe….
Before I could run 25 PSI boost with minimal knock (.7-1.0) O2’s in the 780-820 range. The car ran awesome
Now I can not achieve more than 22 PSI consistently (it might spike in first to 25 PSI) and knocks like there is no limit on the scan master (I saw 27.0 degrees) when the timing curve comes on in the chip… Second and third gear the O2 starts taking a nose dive to low 700’s but seems sporadic along with the knock. Also I have been having some sporadic surging idle problems.
The alky pump is fine, that is the first thing I thought to check because of the O2 MV and all the knock but that still doesn’t explain the other problems?
