with stock chip at wot there is no control of fuel coming from the intake readings so 230 or 255 whats the difference ,
you are at the mercy of the chip builder so pick a good one , i chose turbotweak, he goes over whta your car is and builds a chip around your specific mods and plans , if its not right he will work to make it fit your car , yes you will have to add the fuel and adjust the timing in the chip if you choose to run higher boost or different octane than chip was burned for but thats what tuning is all about.
I have never adjusted my fuel with regulator and run many different varied boost levels , on newest TT chip there is a 20% +/- adjustability on fueling which should cover most fueling needs (boost levels) and you can add or renmove fuel as long as your injectors can meet the need and now there isa 1st gear fuel trim and 10* +/- timing adjustability to cover any octane you choose to run ,
i run one chip in my 87 , a TT alky , and have run it from 21 -30psi with stock and TA49/TE44 turbo , the chip is tweakable and i adjust fuel through the chip , i personally like the fact that my fueling isnt sensor based but based on what it should need , with a TT chip the O2 can be yanked out and the car will still run fine
on my 86 i have run on the one older TT chip , i do have two chips , one street and one race (more timing little more fuel ) and so far 10.5 on race chip with 93 and little 112 and 10.7 93 alky (still tuning) . both are non alky chips and i used the street to safely ease the change from gas to 93 + alky but now after seeing where the car is at I'm back on the race chip and running 93 + alky and have room in chip to add 20% more fuel and add 5 degrees timing in 1-2 and 3-4 gear .
and i run the translators at base settings
