williamsGN 'Horse sneeze' addict Joined Sep 20, 2007 Jul 19, 2018 #1 Went to replace mine and realized there were none there ! Anyone care to post a picture of the top area with the strips visible. Thanks
G gsgnnut Active Member Joined Mar 31, 2014 Jul 19, 2018 #2 I need to see this too, my tops rattle as well. Thought it was just the nature of the beast?
blackazz Not a Gn TurboBuick.Com Supporter! Joined Sep 1, 2008 Jul 19, 2018 #3 I can in a hour or so. Sent from my SM-G920T using Tapatalk
blackazz Not a Gn TurboBuick.Com Supporter! Joined Sep 1, 2008 Jul 23, 2018 #5 These pic work Sent from my SM-G920T using Tapatalk
R rag231 Well-Known Member Joined Apr 30, 2005 Jul 24, 2018 #7 Also check your ttop bushings. When you secure your ttops into place there are bushings that the "locking rod" goes into on both sides.
williamsGN 'Horse sneeze' addict Joined Sep 20, 2007 Jul 25, 2018 #8 Have bushings in both fronts, but none in the rear... how about your guys cars ? TIA
Anthony P sharing knowledge with those who care to listen Joined Jan 24, 2007 Jul 26, 2018 #9 bushings in both fronts as front opening is a larger diameter than the locking pin. smaller diameter opening for rear pin, no bushings.
