rechrome original GN steel wheels
the process costs about $250 per wheel. The reason being is that the wheel is taken apart into three pieces - the inner and outer rim shells and the center section. this is the only way to do the job correctly. the three pieces are stripped to bare metal, re-chromed, welded back together and balanced.
Look at a chrome GN wheel from the back and you will see the inner weld seam. From the front, the outer weld seam is hidden where the outer shell meets the center section. In addition, since that area is so close, it has to be taken apart to chrome properly.
The wheels are taken apart by a CNC milling machine and takes a few hours to do.
Jim Lyon at TruDesign Wheel did a set of original wheels for me and they are perfect - almost look better than when they were new. While we should support our sponsor venders when ever we can, Jim does the work for some of our supporting venders. I would address Jim directly with any technical questions.
Some venders will put your center section in new rim shells. If you do this, you will loose the date coded information from the inside rim shell. If you are keeping the factory 15 x 7 size, I would suggest using your original parts if you can so you don't loose the date codes and part #'s.
Again, contact Jim Lyon at TruDesign wheel directly with any technical questions. You won't be sorry.
-Anthony
