Combo in sig.
Stall (manufacturer unknown) is currently 3500-4000 on a TH400 with a 3.90 gear.
Cam is Comp 242/242....can dig out cam card if that helps/needed.
Originally had issues spooling turbo, due to Hooker headers, bought some TA 4 bolt headers, installed them, and spool was greatly increased, but converter is older and may need to be addressed.
Cal tuned the car, before fuel pump ran out, and mentioned the converter felt too "loose".
Spoke with Lane/Dusty at PTC and they recommended a 19 blade 9.5 3200 stall.
Car is built to run 30-35lbs on C16 only, no 91 and alky tune here, and will be 20% street/80% track.
Turbo is older, I am aware, and info from search was very scarce on this turbo.
Any S2 cars run or still run this turbo?
Seen many V8's running this, but not many V6s...is 274ci enough to spool quickly, something of this size?
