Speedo gear for 28" tire
Just leave it Not worth changing
Only a few mph at highway speeds I ran 28s 27 and 26s Never changed the speedo It will read a little low but not worth changing imo
You can get gears or add-on ratio adapters at www.transmissioncenter.net, but figuring out what you need can be complicated. Come to think of it, even finding where the stuff is on the site isn't easy (look for "Speedometer World").
that few miles per hour can make a difference on whether you get a speeding ticket or not. And points on your license. And insurance hassles. And......
How did you change the driven gear? Does it just pull out of trans once I remove the speedo cable ?
Once the speedo cable is disconnected at the transmission, there is a retainer bolt that needs to be removed--then the driven gear assembly basically pulls out. Have a pan handy, trans fluid will most likely come out depending on how you lift the car up to get under it....
Seems to me the black gear is correct for the 28" tire.
Thank you !!! ....you are correct, the black gear is for 28" tires
All changes in speedo gear(s) need to be based on percent of the ratio of the two gears. With that said you need the exact tire height as it sits on the car and you can go on any of the online calculators and determine the gears you need. 10, 11, 12, and 13 tooth drive gears are available. The stock drive gear is 11 teeth. Use this info to determine what driven gear you need.
My car came with a gnx dash with a VDO speedometer. When the speedometer reads around 90 mph, I'm actually going around 70. I looked at the calculator but I would need to know the number of revolutions per mile. Can anyone help me? Thanks.
OK, how much will I be off from stock tire height?
About 6 mph at 60 mph I have 28" tall tires. Had a buddy drive beside me with a certified calibrated speedo (cop car).
26" tall tire 807 revolutions per mile
28" tall tire 747 revolutions per mile.
Try these:
http://www.f-body.org/gears/
http://www.wallaceracing.com/speedo-calculator.php
http://www.wallaceracing.com/Calculators.htm
Tire Info, rolling circumferences etc..
http://www.gnttype.org/techarea/suspension/Tirechart2.html
Trans Info. >> http://www.maliburacing.com/auto_tranny_id.htm
2004R gear ratios are:
1st = 2.74
2nd = 1.57
3rd = 1.00
4th = .67
Revolutions per mile will be a little different for each tire brand and series. Close, but not exactly the same. This is because the tires are constructed a little differently, and flex a little differently at speed (or even at different speeds, in different conditions).
So you get in the ballbark with gearing. But it's probably a waste of time calibrating your speedometer, if doing so is difficult, unless you plan on buying exactly the same tire every time forever.
This is why I suggested measuring the exact height with the tires installed in the car.
