Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
I am stepping up my power so need to graduate into a much larger fuel delivery solution. Over last summer I converted over to Teflon fuel lines with AN 6 and 8 fittings. So I had my existing hanger converted to AN fittings as well. This is a neat setup as it allows you to have AN setup without buying an expensive hanger. I just flowed the pump as I emptied the tank. It delivered 5 gallons in 3 minutes at 16 volts. This insures it's operational at 255 lph or greater. The hot wire comes as well. Since the setup I am purchasing comes with another hot wire I do not need this one. The fuse holder is good...relay works fine. Sock on the pump intake is clean, rubber O ring comes clean too.
The sender itself was bought last year for 129. Got 40$ in the AN fittings being soldered on. Pump and wire kit $180
Selling it all for 200$
