GNVYUS 1
- Dec 15, 2002
I'm trying to get back into the game and the game is still screwing me over. While I'm bending over I've got some things to sell.
Devil's Own Universal Alcohol Alky Kit $75
Shureflow Pump with 90 fittings, Hobbs Switch and Relay. This was my preturbo kit and has low low miles.
Preluber Oil Prime Kit with extra Pump $175
These were the thing for a while and mine is from ESP. This works and so does the extra pump and the brain box. The extra pump alone has to be worth $100.
Stock Modified fuel hanger with -8 -6 outlets $40
The float arm isn't accurate reading fuel on the analog gauge so you'll need to address this.
Casper's fuel pump hotwire kit $25
Works great had to go Racetronix for SS pump hanger.
These parts need to be cleaned, sit in solvent etc and THEN put on your car. These have the ethanol white chalk build up so DO NOT put these on your car unless you clean them. I know some members have the ability or patience to clean/repair issues like this so I don't wanna just throw these out.
Champion Rails, -8 feed and -6 outlet fittings, rear braided cross over AND Accufab regulator with welded -6 return fitting. $90
Stock modified fuel hanger with -8 and -6 fittings on the outlets. $75
This should clean up easily after a few minutes in solvent. Float arm reads accurate on analog gauge.
Seimens 80lb injectors $50
(MUST get flowed/cleaned and needs new orings) Do not install these as is, had low miles.
I can get more pics if needed, PayPal available and shipping is extra.
