We would like to thank
Gbodyparts.com for sponsoring the Index categories at the 2011 Southern Buick Shootout.
*The class will run on a 8 car minimum to pay full purse, there will be a 10% payout reduction per car under the 8 car minimum.
Turbocharger Sale!!$599.00
These units are a perfect solution as they deliver a high quality product for those on a budget. Well, after a few weeks of discussion, the units have been priced and are available for sale.
These will be available with either a T3 4 bolt, T3 5 bolt, or Buick 3 bolt turbine housing. Mitsubishi housings are NOT included in this offer. All units will feature a 360* Race Bearing setup.
These turbos carry a 1 year warranty from Precision Turbo
3231= recommended converter 2,400 stall HP rating is at 490 to the flywheel
3431=TE34 reccomended converter 2,600 stall Hp rating 545 to the flywheel
4431=TE44 recommended converter 2,700 stall HP rating is 580 to the flywheel
6031=TE60 recommended converter 2,800 stall HP rating is 600 to the flywheel
6076= recommended converter is a 3,200 stall Horsepower rating is 610 to the flywheel
All of the entry level turbochargers come with an E-cover and a cast back plate but include a 360 thrust bearing. These turbos usually come with the 270 thrust but are upgraded to the 360.
Normal retail is $921.99
NOW on sale for a limited time for
$595.00
Add Heavy Duty actuators for $89.95
Oil Feed Line for $29.95
