Shuterdown
- May 23, 2004
Hey guys...I don't know if anyone has ever had this problem...but I have the SMC kit.
When I try using turbolink, the program works fine until the alcohol injection turns on (under boost). As soon as the unit is in operation, all I get with turbolink is invalid readings...until I let off the gas and the pump stops working.
I've tried running 15lbs of boost on and off the alcohol, and Turbolink reads fine when the alcohol isn't on. What I'm wondering is, where could this interference come from? I have the SMC controller powered off the fuse block...
Thanks in advance,
John
Thanks in advance,
John
