Anyone have good luck with the RJC boost controller on a basically stock setup car? Does it eliminate boost spike at all?
I'm still having bad boost spike. If I nail the throttle, it jumps to ~ 20 psi more ot less, before it settles to where I have it set at. (Currently 17 psi, 18 w/ cutout open...) I'm using the stock setup with a new wastegate solenoid. I like it this way because it spools fast. If I just loop the compressor directly to the actuator, the boost is WAY more stable, but the spoolup lag is unbearable. (Because of the constant pressure to the actuator).
I was looking at the RJC controller that goes in the boost lines. It eliminates the usage of the solenoid and just goes between the compressor and the actuator, correct? How fine is the adjustability? Reduce spike?
Any feedback appreciated. I'm running stock turbo & I/C.
