After the no oil pressure debacle that turned out to be a poorly machined front cover. We drilled the oil supply channels to actually work as intended and got the car started and running. I took the car for a ride and there was a lot of vibration and noise coming from the rear differential. It turns out that the ring and pinion was severely galled, and needed replacement.
The cheapest vendor turned out to be 9-Bolt.com from Australia. $445 including shipping for the gear set and bearing kit. This will get me back on the road. Ultimately, I believe I need a more durable differential to take the power of the new motor combination...mo money...mo money...that seems to be the mantra!
