Ok so I figured out I burnt a couple wires. It was only the brown and the green.
At that time though when I hit the test button I could here the pump run.
Now the pump is not coming on the lighht stays red. If I hit th etest button all the lights come on but the pump isn't running.
I checked the ground and checked the brown wires on the top of the pump. Still nothing. The car has been down for 8 months, but this had happened before at the track, I thought it was a ground, but it started working again.
Could the switch on the yop of the pump be the culprit?
