My general rule of thumb, when it comes to blow off valve on a Buick is this.
If the car runs a factory MAF sensor, a standard vent to atmosphere B/O valve could cause some driveability issues. When I have this question asked on a Buick application, my first questions are this.
- Will this be going on a daily driver application?
- Are we replacing a stock turbo with this new unit?
- What is your driving style, IE: do you do alot of partial or half throttle driving?
- Do you run a front mount intercooler?
Reasons:
A daily driver application will see more partial or half throttle driving behavior than a wham bam dragstrip only combination. With a stock turbo the air flow capabilities at 5-10psi are nowhere near as great, as say a 6262 at 10psi. And unless you have a built 235+ ci setup with good flowing heads and cam that can take the extra amount of air flow, you will see some surging issues. Especially on front mount applications. This was a very common issue with the old TE-44 and front mount combos back in the day. I personally saw it myself with my last car when I went from a TE-60R to a PT6776R straight S cover. Normal no boost or WOT was fine. But part throttle with a few 5-7psi would surge like crazy. I scored a deal from Don on his old PT6776R turbo with a ported shroud H cover and no more surging under the same conditions.
In some full race applications, (IE: high boost non daily driver style application) we have seen a slight loss in power on ported shroud comp covers vs straight inlet style comp covers. Exactly how much varies application to application. This is why we typically try to spec a ported shroud comp cover for street driven applications and a straight inlet style comp cover on a more race oriented application.
Ported Shroud 6262S
Straight inlet 6765S
I personally do like to see a ported shroud comp cover on a street driven Turbo Buick, especially on a stock motor with a turbo sized from 6262 on up.
Hope some of this helps a little.
Patrick
