I need an opinion on the attached dyno graph and the performance of the PTC 9.5” converter I’m using. The graph compares one of last years dyno runs using a West Coast Converters 2800 stall L/U (locked up) with my current PTC 9.5” 3000 non-L/U. The top light blue line represents last year’s torque curve (locked up). The upper light red line represents this year’s torque curve with the PTC. The numbers inside the graph are meaningless as they are just where the reference bar happens to park on the printout.
One thing I see is that I’ve given up a huge amount of time where over 400ft/lbs of torque is being applied to the pavement. The PTC doesn’t catch up to the locked up WCC until about 4700 rpm. Then, when the PTC does “couple” it really drags down the rpm as indicated by the curly-Q. I then continue to apply some decent torque, but only to about 5150 rpm where it drops below last year’s curve again. Although, HP stays somewhat stable, but still lower than last year.
The AFR is quite different than before and at 14.4AFR, I would assume I’m loosing quite a bit of power, thus making the comparison suspect overall. The dyno O2 didn't agree with my PL AFR readings, but the trends were parallel (his showed lean, so did mine). But, comparatively, the AFR is pretty close in the 3700 rpm range where the WCC outperforms the PTC by a mile.
I’m headed to the track tomorrow to see what the car does in real world conditions, but my main question here is why does the PTC couple so hard that it drags the rpm way down. Can the converter be reconfigured to avoid that or is that normal? I can actually count the time that it takes for the rpm to flash, then stop rising (the curly-Q), then start climbing again. I suppose if I’m anywhere near that rpm after the shifts, I guess I’m making decent torque, but it sure doesn’t seem like it will outperform the WCC given the narrow band of time it’s above the WCC numbers.
Thanks!
Thanks!
