I went open breather(aftermarket) that vents. It got soaked, oil would get pushed through my turbo seal(at times) high crankcase Pressure build up. I had a little smoke at idle 4-5 mins worth. Went through alot of crap thinking it was bad gasket, cracked heads, i switch the breather back into the intake. No problem since. I used a mr gasket breather w/ outlet into the intake.
I toss that open breather away, Again other might say no problems with them, some might say x2. My open breather was on a tall tube, still got soaked. Not sure if you being IC would make a difference, hope this helps.
