Stock GN valve cover oil filler cap issue
modular46
My valve cover oil cover just came off and was laying in my engine bay. I tried finding a quick fix for a replacement screw on cap but none of them fit. Anyone have any suggestions on how to fix this without taking the valve cover off or any replacement cap I can use till I can get the valve cover off?
I’m confused. Have you lined it back up & just twisted it? Nothing there to fail.
You may need to bend the tabs out a bit to help hold it to the cover.
I can put the neck back in but its very loose. The rubber gasket that compressed it for a tight fit has worn away and is gone. THere's no way to keep the neck in the slot tight.
I have a nice used stock filler cap and tube if you need it. I have after market VC's so it's just sitting.
No rubber gasket.
FWIW, I think '87Turbo"T" hit the nail on the head.
