Precision PT70H Garrett .63 ar and the bigget housing
turbo96max
Had this posted w the bigger Garrett turbine housing without much movement. So I took the turbo to MIC turbo in miami fl.
They machined a stock .63 housing to fit the p wheel. Checked the turbo for a clean bill of health .modded the wastegate hole for external wg and milled the housing flat.
Turbo comes w both housings and a new gasket.
Everything $600 obo
What happened here?
Shop welded the wg puck hole shut.welder must have sucked and they needed to grind it a bit.you can tell from the inside its a round cut steel plug.
If anyone is truly interested I can have then re open it and make sure theres a flat machined surface.
