DonnieShort
Who's Next?
- May 27, 2001
First impression is this thing is freakin' awesome
Install was very, very easy and straight forward. Since I run the TPro with the EGT adapter, WB and 3 bar map, they all were real easy to install to the IO connector. With these hooked up you can watch and log WB AFR, boost/vacuum and EGT temps. Not to mention everything else that is displayed.
On the gauge screen is RPM and MPH as the larger gauges and 9 smaller gauges that include O2 volts, knock, spark, boost, TPS, injector pulse wideth with %, AFR, MAF and LV8.
The data screen shows everything you can imagine.
One thing I would like to note is you can datalog without the laptop hooked up. It has internal memory that will store 30 seconds of data for later viewing.
Eventhough this version is beta, it works great and I look forward to the finalized version. This thing rocks and will be well worth the wait.
One interesting thing to note for those like me who run the TPro. Since PL uses a USB port and TunerPro uses a serial port, you can run them both at the same time and datalog with them both at the same time. No that's awesome!!!!!
