pl file please review
buick86
Im having trouble chasing down a rich condition at wot. stock motor,turbo,009 injectors,razor alky and gen 2 translater with ls1 maf and ft. extreme g chip. This run had akly inital set to 11:00 and gain set to 5 Im thinking I should turn inital down to 10-10:30 and gain up a little . Im pulling fuel out with translater, low 800 rpm 11% low 1200 rpm 3% and - 5% mainscale to try and solve rich cruise and had to add it back in high tune to keep timing right. Any help would be great Thanks!
  • akly 5 see notes.dat
Your injector duty cycle is at 72 percent at only 4,000 RPM. At WOT you may be running out of injector.
Would,t running out of injector give me a lean condition at wot? Im just trying to figure this out. Thanks for reply.
If adjust tps and stay on gas longer to get higher rpms then I will know what my true afr is,thus possibly running out of injector .Is that correct?
