Amazing numbers Who has the datalog file from the fast dash? I want to see the converter slippage.......
norb
Is it a 20 vane stator? Whats the rpm on the shifts? And the rpm drop after the shift?
Not sure on how many vane it is but i shift it @ 7500 and last week it was around a 900 Rpm drop at the shift.
Puts you at 6600 RPM stall speed, it could be a 19 vane stator based on those numbers. What RPM did the motor make peak TQ on the dyno? You must be well near 1350 RWHP at your current mph?
Tire size, weight, gear, hp, shift rpm are just a couple variables that determine what stall is needed. Flash stall is effected by all these as well.
How much does the car weigh?
2450 with me in it
That is pretty light..........damn
If this car was 3450 he'd be flashing the converter over 7000 rpm. Weight plays a big roll in what you can get away with. Less weight stresses the converter less so it can be looser for a given engine combo. He's making plenty of power with more to go. I'm just using this as an example for guys to learn from. At this power level in a full weight car he would not be able to run this converter this loose without having to turn the motor 8,000 plus. Because of the weight I can run it on the looser side at his power level which makes it easier to spool yet still couple.
