dan lephart
- Nov 10, 2002
The perma dry valve cover gaskets 50156T have two tabs, part of the steel shim, at the bottom that overlap the inside ridge of the cover. These need trimmed off so the gasket fits inside the cover rim??? You would think they should be made to fit without any "modifying"
:biggrin: Thanx in advance - Dan Lephart:biggrin:
