I can take it if you guys think anything is a dumb move or could be improved upon. It's pretty much all done or being done, so I can't go back on it now, but in TOTAL honesty, what would you do to improve upon this set up in terms of performance. Obviously cosmetics are subjective, so no need to address that. In terms of pure performance, what would you do to improve the car based on what I've already done?
BTW, I don't need an alky kit. I will be running either MS 109 or C16 full time.
THANKS!!!!
1986 Grand National
Stock Block bored .30 over
Comp Cam timing chain + gears
New rod + main bearings
JE Custom Pistons
Comp 212 Hydraulic Roller Camshaft
Comp Hydraulic Lifters
CV Pushrods
Cometic Head Gaskets
Manley Valve Springs
Total Seal Gapless Rings
Competition Valve Job
Ported Intake/Exhaust Runners + Bowls
Reconditioned Stock Rods
Reconditioned Stock Crank
Precision TA52 Turbo
Precision 60lb injectors
Precision Front Mount intercooler
Precision Fuel Pump
Tial BOV
RJS Boost Controller
Accufab Adjustable Fuel Pressure Regulator
Accufab 65mm Polished Throttle Body
Accufab 65mm Polished Instake
3 Inch Impala MAF Sensor
MAF Translator
MSD 8.5mm Plug Wires
Billet Vacuum Block
Polished Aluminum Turbo Shield
Polished Aluminum Washer Cover
Chrome Battery Cover
Polished Aluminum Alternator Cover
Buick Motorsports Coated Valve Covers
Custom Virtual Works 3.5 inch Exhaust
Custom Virtual Works 3.5 Chrome down pipe
Custom Virtual Works 3.5 inch Polished Intercooler Pipe
Custom Virtual Works 3 inch Polished up pipe
Big Mouth MAF intake w/K&N cone
QA1 Pro Coil Over Rear Suspension
QA1 Pro Coil Over Front Suspension
HR Parts Rear Sway Bar
HR Parts Street/Strip Rear Suspension Package
HR Parts Upper + Lower Rear Control arms
Poston Driveshaft Loop
Turbo Tweak Chip for 109 octane
Street/Strip CK 200 Trans
3200 Stall CK Converter
Eaton Posi
CenterLine Auto Drag front + rear rims
MT ET Street Radials Front + rear (275/60/15 rear)
Smoked Signal Markers
Smoked Side Markers
Smoked Taillights
LED Taillight Conversion
TR Center Console Plates
RJS Billet Horn Ring w/TR GN Horn Logo
Poston Console Raiser
20% Tinted Windows
Poston Fiberglass Rear Bumper w/Aluminum braces
Poston Fiberglass Front Bumper w/Aluminum braces
Poston GNX Dash w/VDO Gauges
Assorted Chrome Accents
THANKS!!!!
1986 Grand National
JE Custom Pistons
CV Pushrods
Precision Fuel Pump
Tial BOV
MAF Translator
Billet Vacuum Block
Eaton Posi
Smoked Side Markers
Smoked Taillights
20% Tinted Windows
