Steve, I hope to be taking alcohol to a new level..may actually run better than your C16..fingers crossed..
If you were to run a .045 jet and were able to throttle the alky the motor injests..bet you could run more on alky than you currently do.
The way I see it..your requirments for alky at 15 lbs and at 25 lbs are way different..so setting your jet to the 25 lb level cuases you to run way too much alcohol at 15 and make the car lazy..until it gets to 25..if you can make the car trimmed at 15 and 25..I would bet you would pickup a bunch..
Notice this...most fast alky cars run mid-high 11's ..most have excellent trap speeds..118-120.. You have race gas cars that run less MPH yet ET better..Why?? Becuase we're spraying way too much alky down low cuasing the motors to be lazy..see if the car is rich its lazy..if its lean..its angry..Get your car angry on alky..you will see the
Also..lets say you run street tires..richening(more alky) the launch will yield a better 60 foot..on street tires.
Back under my rock..
