I just checked ebay for the Tomco 22008 cap that I saw for sale,but it sold. The only other cap is the Caspers cap. The only other way to get a cap is to buy the whole sensor. There's one on ebay. I think Standard still offers the whole sensor.Does anyone offer the original GM cap? If not whats the next very best option?
Thanks.
Did you try the cap,that you believe to be bad,on another engine?Does anyone offer the original GM cap? If not whats the next very best option?
Thanks.
Thanks.
Well I have a Caspers cap from my stock ignition days but I've heard even some of those were problematic at times.No one, including GM Parts, never listed a stock cam sender cap being available.
Is there no other cap?Did you try the cap,that you believe to be bad,on another engine?
I'm not sure if the cap is bad. The car is running well at the moment but it left me with a "no start" at the carwash. Engine was dry so I can't blame it on water. Car restarted after 30 minutes of setting. I can't really diagnose whats not broken at the moment so I'm replacing the FP relay/crank sensor and cam sensor cap and hope one of the 3 was the culprit. I'm hoping it's not a TR6 issue.Did you try the cap,that you believe to be bad,on another engine?
I would still suspect water being the culprit. Check ECM plug for water/corrosion.
He was having this problem before he washed the engine.I agree! Seems odd that it started right after a car wash. I remember one time I washed under the hood. My car sputtered all the way home. When I plugged in the lap top it showed that the voltage was not linear on the TPS. Once it dried it was good. It's been 10 years and still the same TPS, and no more washing under the hood for me.
I will today. Thanks.I would still suspect water being the culprit. Check ECM plug for water/corrosion.
I did not wash the engine. Just the car. Engine was dry. Thats what threw me off.He was having this problem before he washed the engine.
Is this the first time the engine failed to start?I did not wash the engine. Just the car. Engine was dry. Thats what threw me off.
$185.00??????https://www.ebay.com/i/112130660002?chn=ps&dispctrl=1
If the link doesn't work, just search "Walker Products 235-1006"
Yes. Car has never hicupped before. Very dependable.Is this the first time the engine failed to start?
