86regalttype
- Dec 14, 2014
i just had the head gaskets replaced due to one blowing exhaust out the passenger side, now I need to know what type of oil to use? I have a 1986 TType with a 3.8 SFI Turbo.
Thanks, I didn't do a search. I read that a lot of people use Rotella, what is the ZDDP additive do?
I get a kick out of all these oil post, do this and don't do that ?? ANY oil will do the job if it contains the right amount of chemical ingredients you need for a GASOLINE engine. Yup this oil has this and that oil has that but how many give you ANY numbers ?
People on here saying DON'T put that ZDDP in your oil and I did this and I did that and my engine is fine. Better do a search and get yourself some sound advise about what oils contain and HOW much !!
PS. Yup VR-1 racing oil has a high amount oil zinc BUT is it enough? I know do you?
You were right, what a can of worms! The previous owner used Rotella, just got a message from him so that's what I will use. Thanks for all the tips and advice.You are going to get many answers but the general consensus is add ZDDP to whatever oil you use unless it already has ZDDP in it. The search function will bring up many threads with this as a discussion also.
I used to use rotella yrs ago , it doesn't have the zinc it once had moved over to vr1 20/50 still going strong ten yrs . If car is still flat Tappett cam add zddp , I went roller when had motor redone . I think the brad penn is the best out there , ran it in my 750hp Pontiac street strip car with nitrous for yrs . When sold engine took pan off and it was beautiful in pan just normal bearing wear , looked incredible inside.Actually having a discussion with a guy right now about this. From my own experience my car with 56k miles or so was run only on Brad Penn. You can see what the inside looked like in the Virginia area thread where SteveV posted pics during the rebuild. (believe it was titled "made a new friend today") Car was run hard but looked mint inside!
