I had one in there that stalled at 3,200 at 0 lbs. and it stayed at 3,200 on the brake until about 5/6 lbs. of boost and the tires would break loose. It was to tight and I had it tweaked to loosen it up a little.
I have a 3,500 stall now and I will post logs as soon as the bugs get worked out elsewhere as I need to get my tune right before I go hammering my car.
If you have an open mind and we don't get into a pissing contest I will hopefully be able to prove that what is being built on a custom [customer needed basis] is better than what PTC is offering.
The PTC 9.5NL that was provided to this converter builder was cut open and after looking at how they are built was improved upon and installed in the same car that it came out of that runs in the nines.
His is a true billet converter, unlike the ring that is machined on the PTC [very good machine work BTW among other features which makes the PTC a good converter but there is nothing special about it from what he says, he has built a better converter as evidenced by how his converter is performing in the same nine second car the PTC came out of and it picked up a couple of tenths over the PTC.
I've been told that it dosen't fall on it's face like the PTC does by dropping the rpm's to much and launchs off the trans brake better also decreasing 60ft. times.
There is a lot of testing going on in various cars of varying power levels. I will admit that I've had my converter adjusted three times to have it fine tuned[at no cost to me] and now it feels like it's on the money. I feel confident that it will put up numbers that will impress you and make you think twice.
His are a single disc that don't rattle and will hold over a thousand HP, but more importantly over a thousand ft. lbs. also. He will warranty it up to 1,500 HP.
