I have Razor's kit. When trying to prime the pump after it's been sitting awhile, the pump won't run when pressing the test button. The red LED comes on, but the engine won't stumble at all. Disconnected hose doesn't show anything coming out either during a test. But, the pump runs full bore when I jumper the wires at the MAP, so I know the pump works. Which wire or connection should I look at first? Hoping this is a common issue someone else ran into. It worked fine when first installed two years ago up until recently. Thanks!
