Im not saying there is anything wrong with the chip but with alky I would like a chip I know that is set up for my injectors my timing my fueling my boost ect
You can run any chip with alky. It's already been determined that he has a 93 chip and,of course it's burned for his injectors. The timing is okay becuase it's a 93 chip and because it does run good without spark retard sometimes. We also know that the fueling is correct because he is very rich and because he has a 93 chip. A 93 chip wouldn't be burned for 25 lbs of boost. I think the two most obvious things to look at,that would create dramatic fluctuations in A/F ratios would be the alky kit and the MAF. He's already said he has another MAF and alky isn't even needed at that boost level.
Turn the alky off!
