I bought a fresh, never used Brian Hoffer 200r4 from a board member in 11/2011. The previous owner bought it from Brian Hoffer about 3 years prior to that but never used it. Before I installed it I pulled the pan and looked around and it looked great. It was obviously a rebuilt and unused transmission just like the seller had stated. I put the trans in this past week with a new 9.5 PTC converter and when I test drove the car it would not shift from first to second at any RPM. I adjusted the TV cable but still no luck. I brought the RPM's up to 1500 in park and pulled and released the TV cable several times in the hopes that the TV valve might be stuck and this would free it up but no luck. The TV cable seems to be working correctly in that it is spring loaded when you pull it and it snaps back to its original position with no problems. I feel like the problem is something sticking due to sitting around for 3 years and I wanted to get some suggestions on what to check. Thanks for the help!
