TT/Ameasap
The White Blur
- Jan 31, 2002
Details of the run:
60'--1.643
330'--4.804
1/8--7.434
MPH--94.88
1000'--9.717
1/4--11.644
MPH--115.17
Screen Name or Car Number Here
EMPTY WEIGHT:stock
BLOCK:stock
HEADS:stock no porting
CAM:stock
TRANSMISSION:stock
TORQUE CONVERTER:restalled d5
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:50#
THERMOSTAT:180
TURBOCHARGER:Ta-49
VALVE SPRINGS:100#
MAF:stock
DOWN PIPE:THDP
EXHAUST:Edelbrock
FUEL PUMP:Walboro 340
FUEL PRESSURE REGULATOR:billit afpr
FUEL PRESSURE:40ish
ALCHOHOL INJECTION:yes
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:K&N
TIRE DESIGN, SIZE & AIR PRESSURE:M&H racemaster 26x11.5x16@15psi
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:Scanmaster2
FUEL:93 octane
CHIP:Turbo Tweak
CHIP TIMING:23 in 1st and 2nd , 20 in 3rd
KNOCK RETARD:2.5
OXYGEN SENSOR VOLTAGE:780-790
EXHAUST GAS TEMPERATURE:no
TRACK ELEVATION:10ft?
TEMPERATURE:80 degrees
PEAK BOOST:24
BOOST AT LAUNCH:8-10psi
MILES ON THE CAR/ENGINE:80k
This thing flys now.
I spun the tires just a little on this run, but still got a good 60' out of it. Im like everyones hero at the track now cause I spanked a new cobra w/nos that was terrorizing everybody!He ran 12.0 to my 11.66 and got his arss handed to him. All I can say is that I am in disbelief. The car performs flawlessly on Razor's PAC controller and Erics Marshall's chip.
Bo
60'--1.643
330'--4.804
1/8--7.434
MPH--94.88
1000'--9.717
1/4--11.644
MPH--115.17
EMPTY WEIGHT:stock
BLOCK:stock
CAM:stock
TRANSMISSION:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:50#
THERMOSTAT:180
TURBOCHARGER:Ta-49
VALVE SPRINGS:100#
MAF:stock
DOWN PIPE:THDP
EXHAUST:Edelbrock
FUEL PRESSURE:40ish
NITROUS:no
AIR BAG(s):no
SUSPENSION:stock
FUEL:93 octane
CHIP:Turbo Tweak
KNOCK RETARD:2.5
PEAK BOOST:24
Bo
