Details of the run:
60' - 2.109
330' - 5.672
1/8 - 8.642
MPH - 82.68
1000' - 11.206
1/4 - 13.372
MPH - 103.82
Turbo Trans Am #850
EMPTY WEIGHT:stock leather/t-top car
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION:stock
TORQUE CONVERTER:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:no
INJECTORS:stock
THERMOSTAT:stock
TURBOCHARGER:stock
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:stock
EXHAUST:stock
FUEL PUMP:stock
FUEL PRESSURE REGULATOR:stock
FUEL PRESSURE:stock
ALCHOHOL INJECTION:no
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:stock w/K&N replacement filter
TIRE DESIGN, SIZE & AIR PRESSURE:stock
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:none
FUEL:93 octane
CHIP:stock
CHIP TIMING:stock
KNOCK RETARD:??
OXYGEN SENSOR VOLTAGE:???
EXHAUST GAS TEMPERATURE:???
TRACK ELEVATION:E-Town,NJ(near sea level)
TEMPERATURE:80*
PEAK BOOST:stock
BOOST AT LAUNCH:0(1800 rpm launch)
MILES ON THE CAR/ENGINE:61,300
It figures that when I used the car two years ago for a shootout with GMHTP that it would only muster a 13.71 @ 97mph and this weekend with no changes it was ripping off some pretty good times for a stock car.
The 13.37 run was my first pass and as the day progressed we started running round robin so my times fell off but still managed to run 13.44, 13.40, 13.58, 13.472, 13.474, 13.59, 13.55, and 13.67. All passes were over 103mph except the last three which were 102, 102, and 101mph respectivly.
60' - 2.109
330' - 5.672
1/8 - 8.642
MPH - 82.68
1000' - 11.206
1/4 - 13.372
MPH - 103.82
Turbo Trans Am #850
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:no
INJECTORS:stock
THERMOSTAT:stock
TURBOCHARGER:stock
VALVE SPRINGS:stock
MAF:stock
DOWN PIPE:stock
EXHAUST:stock
FUEL PUMP:stock
FUEL PRESSURE:stock
NITROUS:no
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:none
FUEL:93 octane
CHIP:stock
CHIP TIMING:stock
KNOCK RETARD:??
TEMPERATURE:80*
PEAK BOOST:stock
