New times for alky
V8Killer
GM speed junkie
of the run:
60' 1.85
330' 5.09
1/8 7.83
MPH 89.51
1000' 10.20
1/4 12.22
MPH 110.17
Screen Name or Car Number Here V8Killer
EMPTY WEIGHT:3390
BLOCK:stock
HEADS:stock
CAM:stock
TRANSMISSION:stock w/shift kit
TORQUE CONVERTER:stock
DIFFERENTIAL:stock
INTERCOOLER:stock
THROTTLE BODY:stock
RJC POWER PLATE:yes
INJECTORS:36 blue tops
THERMOSTAT:160
TURBOCHARGER:stock
VALVE SPRINGS:100 lbs
MAF:stock
DOWN PIPE:stock
EXHAUST:stock dump open
FUEL PUMP:walbro 340 hotwired
FUEL PRESSURE REGULATOR:accufab
FUEL PRESSURE:40 lbs
ALCHOHOL INJECTION:yes PAC
PROPAIN INJECTION:no
NITROUS:no
AIR FILTER AND AIR INTAKE:k&n
TIRE DESIGN, SIZE & AIR PRESSURE:BFG drag radial 255/50/16 18psi
AIR BAG(s):no
SUSPENSION:stock
SCAN TOOL:scanmaster
FUEL:pump 93 octane
CHIP:race gas 110
CHIP TIMING:25
KNOCK RETARD:1
OXYGEN SENSOR VOLTAGE:785
EXHAUST GAS TEMPERATURE:
TRACK ELEVATION:
TEMPERATURE:75 degress
PEAK BOOST:23 psi
BOOST AT LAUNCH:?
MILES ON THE CAR/ENGINE:42,000
Nice Times
That car is flyin with all those stock parts. I gotta make sure the "Wraith" (member on this site) sees this, I just got done tellin him a few hours ago that his 87 GN could go low 12's with a stock turbo! He didnt believe me...Go figure. Momma always said "Some people dont believe sh*t stinks until they get there face rubbed in it!".
Nice times for a stock car! An advice is to change chip to one with a lower timing. That way you are able to run more boost and in most cases the times will get better then.
Daniel
Daniel
Daniel what have you run with alky ??? :confused:
While you were at it you kicked some Mustang's butts on night before Fun Ford Weakend :D I'm working on the video I got of you, I'll have it this week.
Grumpy, got any of those 3" downpipes? I'd be interested in one. Never seemed to hook up with you last year on that.
I have only run one time with the alky. Last year I went to a track and runned a 8.25 on 1/8. No 1/4 times yet :( 60 was 1.99 due to bad traction (as most of the times here in Sweden, our track preparation sucks) I belive I can run a high 7 sec with good traction and tuned car. Oh, my car was not so good tuned with alky on that run either. Hopefully I will make it to the track in september, if I get a IC first.
Daniel
Maybe my statement above about lower chip timing and higher boost was wrong, since my experince with alky tuning is very limited :) As I said, have only runned alky once at track.
Daniel
Most impressive :smile:
Time for some stickier tires there. Just think with a 1.60 that would have been an 11.8-11.85. Actually an 11.7x with a 1.5X.
But tracks can sometimes suck.. good work, nice MPH pickup. Keep an eye on the tune.. and possibly going to a chip with higher timing in the 1/2 will bring down the 330. But making the car angrier will require better tires/track prep.
I have seen TTA's cut high 1.5's on BFG's.. actually remember one nailing a string of 1.60's at Bristol three years ago..
Play with the air pressure. Put them down to 13-14 PSI.. get them really heated.. find the grove on the track.. let'r rip.
Put the car to 12-15 PSI.. if it sticks.. bada bing.. your there :biggrin:
The DR's I run are the new MT drag radials.. times in sig. Using above recipe.
track was pretty good ...they were getting ready for Ford day .... I went sat .... what a waste of time .... like watching paint dry ... did I say I hate bracket cars :rolleyes: :eek:
Dan, do you have any of those downpipes available?
My thanks to Razor & Grumpy, I wouldn't have even gotten close without them :biggrin:
I think I have some left in it with an actual Alky chip........we'll see ;)
ummmm my bad :redface: ..... waiting on 5 more here ... Ill tell ya more next week ... sorry but I thought you got another one :eek: :redface:
No, no downpipe yet. I got some new dr's last year instead.
