Ok, well I finally finished up the install of my new alky kit.
The first thing I did after getting everything hooked up was turn on the key switch with no alky in the tank. I did this because I wanted to verify the low alky level light works, and it does.
After filling up the tank with some denatured alky I had in the garage I observed the red light go out. Then I hit the test button on the remote controller.
At first it was making this funny long beep like sound, but I am guessing that's what the pump is supposed to sound like? Because it took a few seconds before I had to undo the line to the up pipe and then finally some alky came out, so now that's ok.
Before I started adjusting boost I wanted to make sure the kit actually worked, so I took it out on a back country road.
So far, as I read and was told, the clear LED turns on red at 5 PSI, and at 10 PSI it turns green, so now I know that works.
But now I am not sure if this is due to me only running 14 PSI of boost (remember I hadn't yet adjusted anything) but I noticed on the top end it started feeling really doggy, Scanmaster was reading in the 800's with no KR.
And as soon as I turned off the kit (while still in the doggy mode) I regained power again. So now that's got me wondering if I was running a way rich condition on the top end? Is that why it would start feeling doggy after like i think 80 mph in full boost?
Before I do anything, is there anything I should check or change? I do have a Turbo Tweak chip 92 octane street chip, I think I adjusted it for a little more fuel at WOT than stock but I know I did not touch the timing on it.
Thanks!
Thanks!
