6instantaneous6
- Jul 13, 2007
Hey guys, here is the story.....
Had boost set up at 8 lb and showed incredible kr at 11 and jump to 16 kr at about 70-80mph. Figured this was false knock but still turned boost down to 3 lbs just to see what happens. Well, at 3lbs of boost I got 11 degrees or a little higher...let of throttle and then comes down gradually.
Checked out the knock sensor and it was excessively tight...so adjusted to finger tight. After, kr came down started at 4.5 then up to 5.5 @ 70-80 mph and scanmaster read- 839 on 02's.
Here are scanmaster numbers at idle
AF 06
lb 43
lnt 127
bl 106
ats 97
iac 00
AF 06
lb 43
lnt 127
bl 106
ats 97
iac 00
