Not much help can be had on pwc forums, so I figured I'd try here since everyone is always so helpful on topics.
I have a 1996 Kawasaki ZXi 1100 jet ski that had been running perfectly up until last weekend. It's an 1100 three cylinder two cycle engine. After running great for 20 minutes and then sitting for about an hour, I went to start it for the return trip to the dock and it would not start. The starter engaged fine. I pulled the plugs and they were wet with fuel and each one produced spark when cranking. I mistakenly choked it, so I figured I flooded the heck out of it. I let it sit for 30 min, but it still wouldn't light up. I ended up getting a tow back to the dock from my dad, which is quite a humbling trip at 5mph.
Back at the dock, I checked everything over and put some clean plugs in. It still wouldn't start even though I had fuel and spark. I have no idea what to check next. The owners manual is next to useless in the troubleshooting section. It says to check the fuel filter, misuse of choke, pressure in the fuel tank, fuel vent line clogged (don't even know where that is and they never mention or picture it in the manual) I know I misused the choke, but how do you clear a flood? Just let it sit for hours? It did start once an hour later when I was farting around with it, so I shut it off quick (no neutral) and ran to get my life jacket so I could run it out. Needless to say, it never started again. I am going back up this weekend and I hope it starts because it will be such a pain to take it out of dock and haul it somewhere.
