Hello,
I was wondering if the trans cooler made by jegs is anygood.
http://www.jegs.com/webapp/wcs/stor...irect&categoryId=62304&parentCategoryId=10535
Precision machined from extruded aluminum with CNC machined billet aluminum end caps. The inlet and outlet fittings are located on the same end thus allowing installation along the frame rail, core support or anywhere that space is limited. Overall dimensions are 2-1/2" H x 3-1/2" W x 15" L. which translates into 475 sq.in. of heat dissipating surface area with 16oz. capacity. Includes stainless hardware, gaskets and 3/8" hose x ¼" NPT straight fittings.
looks like it would fit perfect where the stock intercooler scoop would be
Thanks alot
CJ
Thanks alot
CJ
