freakazoid
- May 21, 2006
I need a very simple(for dummies) instructions for the connections of the translator plus and the 3 inch maf sensor. I need detailed instructions such as which wire is connected to the coil pack. The colors at the coil pack to what. I attempted to connect the translator plus but the car ran ruff.Also got 2 codes, (it stated bad Maf sensor and bad Ecm). I need as easy instruction because I am about to give up on this upgrade. ( also the taggle switches on the set up). The car has 50 lbs injector and a race chip, don't know if this has anything to do with it.
